Salta al contenuto principale
Lanciato nell'aprile 2010 / processore Core i5 2,4 o 2,53 GHz o Core i7 2,66 GHz
591 Domande Visualizza tutte
Cannot get speakers to work, optical out stuck on
Help!
I just installed a new trackpad on my 2010 MacBook Pro 15"- all seemed to go well, but was challenging as the iFixit guide only covered 2009 and 2011 - once reassembled, the headphone jack is stuck in optical mode all the time.
If I plug in headphones they work, but otherwise, I cannot get the native speakers to work.
Humbly yours,
Dr. Bonehead :(
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
See this Question for several possible solutions.
If this answer is acceptable please remember to return and mark it accepted.
Punteggio 1
3 Commenti:
Thanks for the idea- have tried the match stick/etc., but doesn't appear to be a stuck switch. :(
Any other ideas?
da
Go over your speaker connections to the logic board many times DIY think that they have a good solid square snapped in connection only to find out on recheck it was loose.
da
Hey there! - thanks for your help, I just completely disassembled, and triple checked the connections - as far as the computer is concerned, there is no analog out, unless you plug in a set of headphones. :(
Once you plug them in, it works great with headphones, otherwise, optical is on all the time. - Help!
da
Aggiungi la tua risposta
Jon Brummel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 93
