Why won't my Time Capsule power on?
Was working fine until 2 days ago then power on light went out and won't come back on. There are a few LEDs near the power socket that light briefly when the unit is plugged in but otherwise it won't fire up. Reset doesn't help.
Questa è una buona domanda?
8 Commenti
18 months!? This one has only been in service for 1 month. Glad it isn't full, I don't know what I would do to back up 2 TB - That's what I bought the unit to do for me! Are there any tear-downs posted?
D
da damaclac
If it's only been in service for 1 month, it should be under warranty...take it to your nearest Apple Store and make them fix it!
da Ben Eisenman
By dead, does that mean the fan doesn't in fact spin... nor does the drive attempt to spin up? You confirm that it is not receiving power across the board? In my experience with these suckers, there are a number of them that experience breakage in the solder points on the board... which presents like "plug it in... fan spins... HDD may or may not try to spin but never accomplishes the speed for normal usage, and the LED light on the front will NOT be on. Is this what yours is doing? If so, I have a solution for you that's fairly effective. Thanks
da jcarter
Hi JCarter,
You said that you have a solution for above problem where the Time capsule is completely down. Please detail the solution.
thanks.
da Mahi
Hi,
I have my time capsule since 2006 working perfect, but yesterday died! compleatly, don´t turn on the light neather the disks. I´m not shure if is the problems people saying here, because I haven´t change the disk and died 4 years later not 18 months :P
Can I check if the disk is OK? Should I fixit or just buy a new one!?
Thanx,
BTW were I can test out the serial number, just to see if is the problem about the capacitors.
da Pancho
Mostra altri 3 commenti
