Salta al contenuto principale
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Domande Visualizza tutte
New ssd and osx install failure
Hi guys,
My question is i bought a new SSD in my iMac but when i want to install OSX just wait and i got a message to please restart because the install not completed. After that i tried to reinstall with the internet recovery but when finish a get the folder with the question mark on the startup.
Know someone what is the problem?
I need set up something in terminal before i try to use SSD?
The SSD is Samsung 840 Evo.
Thanks for everyone.
Questa è una buona domanda?
Punteggio -1
2 Commenti
What OS-X version are you trying to install? And how are you going about it.
da
I tried Yosemite but the installer from usb always restart before it done.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hopefully you still have your HD installed into the system - Correct? If that is correct your HD is catching the reboot so the installer is not able to finish.
This is were the utility DiskMaker X is needed. In this case you are prepping up your SSD externally via a USB port using the universal SATA adapter cable.
Punteggio 3
Aggiungi la tua risposta
pwd20 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 269
