Salta al contenuto principale
Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance. Released in 2012
doesn't display anything while sd card is on
After I used reemix 3-in-1 remote controle device on my camera it has stopped displaying any images or any nformation on the screen. but after I remove the sd card it shows my settings but I can't change anything else than shutter speed and apature vaalue.what's wrong withi it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
I have a similar problem. In M mode, when I insert SD card the LCD goes black until I change mode. The most of buttons don't seems to work but they're recognized (all of them wake the camera in standby mode).
Is there a way to change firmware in another than the classic way?
Punteggio 0
I had the same problem as you. Screen blank while memory card was in.
I had a third party grip/battery holder attached to my D3200 that had a cable that plugged into the camera and the grip to trigger the shutter. The cable was only partially inserted into the camera. When I plugged it in fully the problem went away.
Punteggio 0
I have the same problem with mine, £80-£140 for Nikon to repair, depending on fault. However I was told they suffer from fema faults, Nikon know about this, and will upgrade for free. Personally think it’s a nasty piece of rubbish made in Thailand with a Nikon badge on in it.
Punteggio 0
Aggiungi la tua risposta
ned sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,058
