Salta al contenuto principale
The HTC Flyer was released in May 2011. Production ceased at the end of 2011. It was also sold under the name HTC EVO View 4G.
My tablet Won't Boot or Recharge
When I plug the tablet into the charger there is no response and when I try powering up I get a quick flash and vibration although it doesn't boot, I've tried everything. Any help would be great thanks.
Questa è una buona domanda?
Punteggio 9
Aggiungi un commento
1 Risposta
Soluzione prescelta
Your battery may be malfunctioning. Try plugging it into the charger (and letting it sit for a few hours) before turning it on; if it turns on while plugged in but turns off when unplugged, it will need replacement.
To replace the battery, you will have to remove the entire back panel of the tablet and carefully remove the cables crossing over the battery, then replace the battery and move the cables back to their initial position.
If it still doesn't turn on while plugged in, your motherboard may have a faulty component such as a malfunctioning RAM stick. Generally, it's easier to replace the entire component than to replace individual parts, so you will have to procure a new motherboard and install it.
A full guide for both will be available here
HTC Flyer Troubleshooting
Punteggio 3
Aggiungi la tua risposta
Ana sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 38
Tutti i Tempi: 833
