Salta al contenuto principale
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 Domande Visualizza tutte
Computer recognizes iPod, but Itunes doesn't
First, the iPod suddenly showed no music, but still showed that the memory was being used unchanged... Itunes wasn't working with the iPod, but still recognized it.
After recenting, memory used is back to zero and Itunes doesn't recognize, but computer still registers...
Any ideas how to fix?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It depends on your operating system... but format it using a utility you'd normally use to format a normal connected USB drive if you're system recognizes it. This will "corrupt" it.... iTunes will detect it's corrupted and prompt you to restore the firmware of the iPod... that might solve your problem.
Punteggio 1
That did it, thanks!
Punteggio 0
Aggiungi la tua risposta
Mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,040
