Salta al contenuto principale
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
My Galaxy GT-P5110 won't hold a charge or turn on. Please help!
I tried leaving it plugged in overnight, I even took it to the geek squad at best buy, and the samsung salesman...nothing. I bought the tablet in Germany, I don't know if that matters (I doubt it). Can someone please help me solve this issue. Thanks
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
This is a copy of another answer I gave today:
Perhaps because your battery is dead.
Check your charger plug-in module with another USB device to see if it is still working.
If your plug-in is still working, check your cable for physical damage, such as a deep crimp in the insulation on the wire (which might indicate that a wire was broken inside), or a dinged-up male for the tablet.
There are 7 pins in the charger cable, buried down in the slots on that 30 pin connector, and the other 23 slots are empty. You might need a magifying glass and a bright light to see properly.
Even if you can't see any damage, a replacement cable is less than 5 bucks: buy a new one and see if it fixes your problem.
Remember if your battery is very discharged that it might take a while for the power-off battery logo to appear on the screen.
Punteggio 0
Aggiungi la tua risposta
Bryant sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,286
