Salta al contenuto principale
Sprint, U.S. Cellular, and Alltell CDMA version of the HTC Touch Pro (RAPH800).
1 Domande Visualizza tutte
How to tell if it's CDMA or GSM version from outside?
I understand that this phone comes in both GSM and CDMA versions, and supposedly (Verizon?) which have both CDMA and GSM built in.
If so, is there a way to tell which version of the phone it is without opening the case?
Thanks
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
4 Risposte
Risposta Più Utile
Actually there are quite a few different versions of the Touch Pro (HTC Raphael). The Verizon version (Raphael 500) does not have global capability, CDMA only. In addition, the phone has a different exterior than others, a different keyboard layout, as well as 96mb less ram to run applications on the phone whereas all other versions, such as the Sprint (Raphael 800) and AT&T Fuze have 288mb of ram.
There's quite a lot of information on these phones at the XDA-Developer's wiki so here's the link: http://bit.ly/bPnhez.
Punteggio 1
1 Commento:
+ nice answer
da
If you have the Verizon (CDMA) version, there is a Verizon logo instead of an htc logo.
Punteggio 0
as a owner of a Verizon HTC Touch Pro 2 it is a global phone and you have the ability to switch between cdma or gsm. I have unlocked my phone simply by calling verizon customer service and speaking with the travel/overseas department. they gave me the unlock code so that i may insert any sim card into the device and switch to gsm. i have tried this locally with a t-mobile and att sim. it also worked overseas with a vodafone sim.
Punteggio 0
1 Commento:
Can you update your answer to include unlock instructions? That'd be a good resource
da
The Touch Pro and the Touch Pro 2 are totally different phones. The Verizon Touch Pro is NOT Global capable. Only the Touch Pro 2 has that Global capability.
Reference:
http://www.phonescoop.com/phones/phone.p...
Punteggio 0
Aggiungi la tua risposta
Dgreene sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,288
