Salta al contenuto principale
How can you tell if it's 8 or 16 GB capacity?
Model A-1320 EMC No2317
Questa è una buona domanda?
Punteggio 3
1 Commento
What if you don't have a charger to turn it on? How do you know then?
da
Aggiungi un commento
5 Risposte
Soluzione Prescelta
In the main menu, scroll down to settings
From settings select About
Punteggio 4
1 Commento:
Go to the iPod icon in FINDER. Right click and select GET INFO. Look at capacity to determine 8 GB or 16 GB.
da
Model A 1320 EMC no.2317 Is it 8 or 16GB capacity
Punteggio 1
1 Commento:
Have yo checked any of the above answers yet? The numbers your have are only confirming that it is September 9, 2009 Disc Date: September 1, 2010
Order No: MC031LL/A* Model No: A1320 (EMC 2317)
Subfamily: iPod nano 5th Gen Model ID: None
Std RAM: N/A Std VRAM: N/A
Std Storage: 8 GB, 16 GB
But they will not help you with this task.
da
Look on the back of iPod >?
Punteggio 0
I thought most iPods had their capacity inscribed on the back. You can also connect your iPod to your computer and see how much memory you have. It will probably tell you a smaller number than 8 or 16, because you can only use a portion of those numbers for storage.
Punteggio 0
My ipod not showing charging
Punteggio 0
1 Commento:
I've charged it about an hour it won't go to settings,or I don't know where to find it. It stays on music cover flow artist songs videos TV shows I can't get it to do what it's supposed to do. Especially charge
da
Aggiungi la tua risposta
John sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 22
Tutti i Tempi: 31,938
