Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Domanda Chiusa
Losing image when mounting
Hi guys.
Just changed the screen on my iPhone 5 (using ifixit guide here). Everything is fine, but as soon as I lay the screen down for mounting I lose image. When I have the screen umounted and standing up like 90 degrees I get image and everything works fine.
What's wrong?! Why am I losing image, aaarg! Thanks in advance for help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Got little time, so i just copy a answer i had to another post, with similar suggestion for solution: "I had a similar problem once, and found out that it was a bad fitting on the unoriginal screen, that got just a little flexcable-strecth or bend so that it lost contact. The solution for me was to make a preassure piece on top of the fitting plate, that pushed the connector in place when the phone was fully put together again."
Good luck, hope this helps :)
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 52
