Salta al contenuto principale
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
lg g2 won't turn on, only vibrates
lg g2 won't turn on, only vibrates when i am pressing the power button
Please help
Questa è una buona domanda?
Punteggio 4
1 Commento
I have the same issue! I replaced the screen and its doing nothing but does vibrate sometimes. So I'm sending the screen back and thinking it may be possible bad replacement part.
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
When I had this problem, it was the battery. It was completely dead and required an official charger to charge the phone. Worked fine once it was charging with an official charger.
Punteggio 1
I had the same problem, but thank god I'm an Verizon employee. I let it charge all the way and then it worked fine!
Punteggio 1
Still vibrate, so there is the power. If the charging LED light come on when plug charger? It's more likely there is something wrong with the LCD screen.
Punteggio 0
I dont know, honestly. Ive been having the same problem. None of the above solutions help. It vibrates when charged and when the power is held down. No LEDs turn on, and the screen is just black. The only sign of life from this thing is vibration.
Punteggio 0
Aggiungi la tua risposta
Subba sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 11,527
