Salta al contenuto principale
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 Domande Visualizza tutte
My MacBook Air Display is not working, it's broken? (I have a a photo)
I could put the photo now n.n, of my MacBook Air, I dropped it accidentally :( , but I want to know if my Display is broken or a cable inside it, what you recommend me to do?
Questa è una buona domanda?
Punteggio 1
4 Commenti
Can't access the image get: Unauthorized
da
Kevin, use this guide to add images Aggiungere immagini ad una domanda
da
There's the photo my friends:D
da
Thanks for posting the image. Sadly I think old turkey is correct here your display has had it. You can also try connecting your system to an external monitor to help prove this. If the image is good on the external then its a sure thing. See if you can locate a full lid assembly while being a bit more in cost it will be a lot easier to replace.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Kevin, that is a broken LCD. Part of the electronics that is connected to your LCD panel has failed. You could try and see if you find something obvious, but most likely you will have to replace the panel. Hope this helps, good luck.
Punteggio 2
Aggiungi la tua risposta
Kevin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,266
