Salta al contenuto principale
La versione aggiornata del Nintendo 3DS da parte di Nintendo. Presenta schermi più grandi, una maggiore durata della batteria, una densità di pixel migliorata e un design più curato.
My right trigger button isn't working
It still registers but it doesn't have the same sort of springy feeling. Its worth noting I think started after a fall on the trigger. I'm guessing some piece of trigger assembly either broke or got out of alignment. Unfortunately I can only seem to find on trigger repair guides for the 3DS and those seem to be about replacing a flex cable not a mechanical issue (presumably they wore out the actual electrical switch component).
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Usually after a fall the plastic around the button gets bent into the button a little bit or sometimes the button part that is inside the console rubs on the plastic.
What I do is inspect it very carefully around where the button is and find where it is sticking. They I either try to bend it back or I remove a small amount of plastic with a hobby knife or razor blade until it moves freely again.
This fixes the vast majority of these types of problems.
I hope this helps.
Punteggio 2
Aggiungi la tua risposta
Nathan Saslavsky sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,977
