air condistioner in car
compressor and/or pullies make noise
Questa è una buona domanda?
The twelfth and final generation of the Cadillac Eldorado was introduced in 1992 as a two-door coupé.
It is usually one of two things, first if the refrigerate is low and some of the oil and escaped, then the compressor is the actually problem, Usually, by adding a small amount of oil with take care of this. Second, the bearing on the clutch is dry and is about to freeze up on you.
Does the "pulley" make the noise with the a/c on or off or both? It it is both then 2 is the answer if only while the a/c is running then 1 is the problem.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 969
