battery drains fast even after replacement with new battery
my battery drains quickly even after replacement with new one
Questa è una buona domanda?
Make restore factory setting
It's working 100%
it is working great
I did factory reset...
Still having the battery issue. When it gets to 70% after full charge. It goes off. Bought another battery, observing same issue.
This is a common problem in most Galaxy phones,
#Make sure the replacement battery is original and not a knock-off
this appear when the phone have 3 problem 1- maybe the pf ic is damage.2- you charging is not work good 3- you have a lose connection in charging part
Try using ShutApp its a task killing app the "Force stops" apps running even without your notice. Most of the running apps drain your battery really quick as soon as you turn on mobile data or WiFi so I recommend you use or download ShutApp.
I dont know how it works
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 12,444
