Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3531 Domande Visualizza tutte
Domanda Chiusa
Only charging to 12-19%
Hello
I have recently repaired a customers iPhone 5S by installing a new charge port flex due to you having to wiggle the charge cable to get it to work.
I fully charged the device to 100% battery as did the customer successfully for the next couple of days after the repair.
Over the last few days the customer has stated that the phone will only now charge between 12-19% and then stop. Apparently the charge symbol is displayed on the screen
Has anyone any ideas as to what might be causing this or has anyone else suffered a similar problem? The customer is returning the phone next week so I would like a few ideas to try.
Many thanks in advance
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
99% of the cases which I get like this are from a bad battery. I'd start there. :)
Punteggio 1
1 Commento:
I thought it may be and I intended on testing a new battery when I get it in next week. I just found this a little coincidental as I have only just replaced the charge flex and it appeared to charge ok the first couple of times.
Maybe where the customer has needed the repair for a while the battery was not getting complete charging cycles due to having to hold the charger at a certain angle. Maybe this has caused the issue with the battery to develop.
Thank you
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 132
