Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Won't turn on with battery but will with adapter battery shows 100%
I replaced a broken screen. Powered up and everything was fine until I noticed the microphone screen was missing. Disassembled and installed screen and after that it would not turn on.Tried to pwr up with the adapter. When it is plugged in it works but it won't work when unplugged.
Questa è una buona domanda?
Punteggio 1
2 Commenti
I have this same exact problem. Also it says it's always searching for a signal and it can't connect to wifi...would getting another battery fix that as well??
da
Edit - just to add, I was replacing the battery and this happened. Thanks!
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
You have damaged the battery it needs replaced
Punteggio 1
Aggiungi la tua risposta
John sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 81
