On my relatively simple 1982 240D (manual transmission)...
oil collecting under air breather ... and, it turned out, 95% of oil dripping, over time, onto garage floor ... was solved by 2 extremely simple fixes:
the rubber elbow under, and therefore inaccessible short of removing air filter housing,
was cracked and "weeping" oil...
Not even having a new one on hand, a quick fix was to exchange it with the one on top so as to be able to quickly replace it when I got a new one.
AND, 2nd ... the oil filler cap was also weeping oil...
I experimented and finally went with a FUEL filler cap / nice shiny chromey FUEL cap--they ARE interchangeable, SIZE-wise at least.
The FUEL cap on the OIL filler worked so much better/tighter than what was also around $5-$8, an all purpose oil filler cap -- on both 240 and 300D.
(And, yes, I also, in this process, bought a replacement GASKET--fitted it...it wasn't as oil-tight as the new FUEL cap. By fuel cap I mean the standard, all purpose one you find in places like OReilly's...chrome color/rugged looking with squared ridges the new oil filler cap which felt like a black plastic toy relatively.
On 300D ...... more complicated but it SOLVED the problem:
open up air filter housing ... just study what's inside.....
that unit that's the size of half a soup can, black plastic with 2 metal tabs holding a round "end" to the "soup can" .... I found instructions online elsewhere to: put gasket material around the edge, seal it up (relatively)...carefully, with hammer and screwdriver for example, tap those metal tabs back down.....thus creating a more oil tight unit, tighter than it was before adding the black gasket stuff around the top edge ($1 at 99 Cents Only).
.....when we got this 300D at 169,000 mi, 1983, not knowing its history...air filter was lousy with oil, 2/3rds the way around ...... subsequently, after tightening up, as described above, and cleaning out with paper towels of course the whole housing...new CHEAP air filter (expecting to use them up faster than the nice Mann German ones)....was CLEAN after 1000s miles of driving. With no oil collecting inside the housing.
If you have oil dripping onto floor also ... wearing gloves is awfully handy for this ... reach under the 300D housing, feeling for a tube that drains downward to a connection WAY low on the engine ... hard to see--usually covered with oil etc...
this tube you're feeling for is light weight, with curves, total length circa 1- 1 1/2 foot...these connections of this light weight oil tube are just a bigger tube fitting over a smaller nipple / tube--not screwed/gasketed or anything--and can come disconnected...(it might have an O ring come to think of it but point is, you just thunk it over the smaller tube and it's connected nicely.) Feel for it and you'll know what I mean. It was a dripping mess before I figured it out--connected it, rag-cleaned engine...now fabulous.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
