Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
All 3 mics and audiojack not working, lightning dock changed
Der community,
I go crazy. I got a iPhone 5 with a waterdamage. This caused a nand error. I fixed this by booting without Front camera flex cable.
Then the on/off button didnt worked. Fixed by replacing the flex cable of Volume mute an power button.
My last and very hard Problem is that all 3 mics not working. I replaced the lightning Dock with the bottom mic but no change. Also the headphone Jack is not working.
Now i habe absolutely no idea how to go further. Maybe the logic board is Broken at all?
Thank You for every answer.
Regards from germany
Patrick
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
hello this sound like a logic board problem cause there is a mic located on the lighting port and power flex cable and u have changed these
Punteggio 0
2 Commenti:
Hello thank You so mich for your answer.
But i changed only the bottom mic. Not the top ones.
da
There is a mic located on the power volume flex and you changed that
da
Aggiungi la tua risposta
Patrick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 62
