Salta al contenuto principale
won't charging or conecting in my computer
hello i have ipod touch 2nd 32 GB
so i have problem its about i can't charge it or conect it with my pc its still turn off ... but it was working fine i understand what hapend
Questa è una buona domanda?
Punteggio -1
1 Commento:
Take a look at your dock connector on the iPod do you see damaged pins?
da
Aggiungi un commento
1 Risposta
I just experienced the same problem with a used gen 2 I purchased yesterday and the fix is as follows. The battery has drained so low that it isn't recognized by the charger, so the battery needs to be "jump started" so to speak. The same goes for many batteries in devices and even auto's and motorcycles.
So, with the charger plugged into the wall, carefully plug-in & unplug multiple times until it responds and begins to charge. What this does is gives the battery a small "jolt" each time until it can be sensed by the charger. It took my device approximately 15-20 times, so be patient.
Good luck bro.
Punteggio 0
Aggiungi la tua risposta
SIMO STUNT LOVER sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 87
