Salta al contenuto principale
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
409 Domande Visualizza tutte
Screens flicker won't display
My Nintendo 3DS XL turns on fine; blue light powers on and both screens flicker; however, neither of them lights up completely. The blue light stays on so I know that the battery has power and that the system is getting power.
Any ideas? I have checked all of the ribbon cables and they seem to be secure. I am not sure what to troubleshoot for both screens not lighting up.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
This is a common problem with 3DS XL consoles. Most of the time when both screens flicker but don't come on there is a problem with the speaker ribbon cable. This is what I check:
1) Remove the back of the console housing and check the speaker ribbon cable to be sure it is seated all the way.
2) Remove the back of the top case (the back of the top screen) and check the speaker ribbon cable there to be sure it is seated and not corroded.
3) Check where the speaker ribbon goes through the hinge. You will probably find a very small tear in the cable where it goes through the hinge and rubs on the metal hinge tube.
If the speaker ribbon cable is seated correctly on both ends then you most likely have a torn ribbon cable and it needs to be replaced.
I hope this helps.
Punteggio 4
Aggiungi la tua risposta
troy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 36
Tutti i Tempi: 4,093
