Where the memory is stored on the motherboard?
I'd like to know where to memory is stored on the motherboard and if it's possible to replace it ?
Thank You !
Questa è una buona domanda?
Thank You !
Sylvain, the memory IC is C-NAND FLASH;SDIN4C2-16G-944D,16GBYTE (varies depending on your memory),4 reference designator is UME6001. If you post a couple of Hi-Res images with your question, we can point it out for you. Here is the guide for adding images. Hope this helps, good luck.
Hi Oldturkey03,
Thanks a lot for your reply. I will post an image later since I'm doing this research for my sister and don't have her tablet yet.
If i understand you well, the memory chip is located here ?
https://d3nevzfk7ii3be.cloudfront.net/ig...
Here's what I'd like to know. Her motherboard is broken and she's has precious photos she'd like to restore. Based on what you know, could I buy an exact copy of her motherboard and replace the memory chip with hers ?
Thank you one more time
Sylvain
Sylvain, only if you know how to reball a BGA IC.
Do you under the iron place thing
i guess so if there the same motherboard
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,614
