LCD with gray lines or discoloration (help and advice)
Ok so I'm looking for people that have been through the dreaded gray lines after a digitizer fix. I've found people that have had the same issue without a broken digitizer as well.
Most people will say that the LCD needs to be replaced but what the heck is causing this issue in the first place? What am I doing wrong? I've noticed it on all sorts of iPhones and iPads and normally a simple unplug and replug of the flex cables fixes the issue.
Now when that doesn't work I have found numerous people use a slight smack to the back with something 3x will normally fix the issue for an ipad. Mine hasn't worked from that yet but I also took it really easy.
Has anyone figured out this issue and found an easy fix or preventative something?..
Questa è una buona domanda?
The issue is the gray lines going through the apple sign on startup and when it's displayed. Sometimes it's crazy looking colors. Just for reference if you forgot what my title says.
da adam
