Salta al contenuto principale
La versione con solo il Wi-Fi dell' Apple iPad Air, numero modello A1474. Disponibile nei colori grigio siderale e argento, ha un processore A7 custom ed è disponibile con memoria da 16, 32, 64 o 128 GB.
311 Domande Visualizza tutte
The smart case is locking the iPad when it touches the back?
I completed an iPad digitiser replacement, the smart case now locks the device when placed on top of the device, as normal. However, it also locks when folded behind and contacts the rear. I've opened up the iPad again, but I can't identify the magnets or find a solution.
I also can't find anyone else with this issue, any help would be appreciated.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
6 Risposte
Soluzione Prescelta
You smart case magnets are probobly to strong I would just turn the feature off on the iPad
Punteggio 1
Commenti:
Thanks for this. Not quite perfect, but it'll do.
da
Turning it off is NOT a valid solution. Smh
da
Same problem here: after a replacement the cover turns off the iPad from the back, not on the front
Punteggio 1
Same thing happens to me. I thought maybe I pinched the ribbon cables. But without that case it all,works fine.
Punteggio 1
This happens when you don't use a genuine home button, it locks when the smart case is on back or front. Add the original or genuine home button (the ones that come with replacement air screens tend to be copies) and the problem will go away
Punteggio 1
I was in class and then my iPad Air just attached to the desk and the desk is metal and there is a magnet I think in the iPad and the iPad just attraks and it’s just the sid across the camera
Punteggio 1
I have an original Apple Smart Case and never experienced this.
Than i cracked my screen and went for a replacement.
Now I have ghost touches and this magnet thing.
The question I have is the guy changed the digitizer glass so what can he have moved to do this?
Punteggio 0
Aggiungi la tua risposta
transbaconist sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,759
