Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2396 Domande Visualizza tutte
Can 4/4s antenna be switched to match Tmobile's 4G network?
Tmobile only offers 4G LTE to phones that are originally Tmobile or factory unlocked phones. When asked, they say this is because phones from other carriers don't have the right hardware/antenna to receive the full strength of their signal... so other unlocked gsm phones like at&t only get 3G speed.
My question is, does anyone know which parts would need to be switched in the phone, or (if Tmobile is lying) a way to reprogram the phone to get full access to Tmobile's network? I couldn't find info for this anywhere online...
Thank you! ! ! :)
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Kaili Galati , just like con said, the iPhone4 and 4S do not support LTE speeds. However, the iPhone 4S supports 4G speeds, though only on AT&T's network. So, Tmobile is right...:-) Hope this helps, good luck.
Punteggio 3
1 Commento:
Thank you very much!! I wish someone at Tmobile could have explained this to me just as concisely! :)
da
iPhone 4 can't pick up 4g it's impossible
Punteggio 1
1 Commento:
Thank you, I'm glad for the confirmation. :)
da
Aggiungi la tua risposta
Kaili Galati sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 104
