Salta al contenuto principale
This device is T-Mobile's version of the Samsung Galaxy S II. It was released in October of 2011. It was the first Galaxy to include T-Mobile's new expanded 4G network.
15 Domande Visualizza tutte
Why isn't my phone charging?
I was charging my phone early this morning before my game and before i unplugged it, it shut off and wouldn't turn on. Phone was at about 70% at the time and i still can't get the phone to charge. Please help!
Questa è una buona domanda?
Punteggio 0
1 Commento
You can always get the wireless charger if the USB port isn't working. That's what happened with my phone is the USB port got wet and now it won't charge I have to charge it with the wireless charger now. Or I have to blow dry my phone before I charge it or else it won't work. I hope this helps.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
jesseornelas72, check your charger to make sure that it is working. Try a different cable, and check your port for any debris corrosion and bend/broken pins. If all that checks out replace the battery and reevaluate. If none of that works you could be having issues with the power management IC or the charging coil itself. Hope this helps, good luck.
Punteggio 1
Sorry i have ignored the phone brand and model,
This pic is for the Galaxy S 2, and i have marked the Charging dock.
Punteggio 0
Aggiungi la tua risposta
jesseornelas72 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 475
