Salta al contenuto principale
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
Why won't it turn on after screen replacement?
I just made a screen replacement on an RAZR and it looks like it won't turn on. I made the repair following the guide. When I plug the charger, a white led turns on. I tried to hard reset it and nothing happens. What could it be?
Questa è una buona domanda?
Punteggio 3
1 Commento
I've double checked it and it's connected. When I try to reset it. The logo comes up but instead of start up it just goes black and nothing work.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Have you checked the connections of the three display cables?
Punteggio 2
2 Commenti:
Today another RAZR came in with a similar problem and the battery flexible was ripped. So it might have something todo with it too.
da
Question: Did you check the battery? Of the RAZR from your original post?
da
Aggiungi la tua risposta
Edgardo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,170
