Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Domanda Chiusa
Very bad battery time, can't charge, can't turn off?
Hello my friends!
I have an Iphone 5 I've received from a customer who claimed he couldn't charge the phone. So, I put in a new battery and tried charging. Nope, can't charge.
Ok.
So I changed out the charging dock.. Still can't charge. Meanwhile, the battery which was at 80% is now at 60%. You can literally watch the procent go down with a little bit of patience. Even with a new battery/new dock.
Phone shows no sign of being watter damaged/dropped. It's a little over one year old.
I've tried three batteries and three different charging docks, no luck.
Also, if I try to turn the phone off, if turns off for like 10seconds and then starts itself.
Any ideas? =)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
This is U2 failure for sure. Sorry to hear :( I don't know of any US group that can fix that.
Punteggio 1
2 Commenti:
Hey Jess, thanks a lot for your answer. Care explaining what U2 is? I'm assuming it's some sort of component on the motherboard. How is it possible that it "failed" ?
Either way I will send it in for guarantee reperation (They'll switch it out for a new) considering the phone is under one year old.
da
U2 is a chip on the motherboard that controls the logic of the usb/charging interface. As the iPhone 5 ages, we are seeing that this chip is particularly susceptible to damage from non-Apple chargers. The symptoms of U2 failure can be fast battery drain, auto power-on, fake charging, no charging of stone dead battery, and no usb recognition. A phone can have one or more of those symptoms from U2 failure.
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 188
