Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iPhone stuck in recovery mode?
Ok so i don't know if the logic board and mother board are the same thing but i tried to change my iPhone5 battery i was successful but i accidentally but a hole in either the logic or mother board and now it won't come out of recovery mode. The iPhone turns on the screen works but when i brought it to someone to fix they said it would be 225$ for the piece to fix it that is called the "socket medium 1005" does anyone know what this piece is where i can buy it or another name for it? or anything else i can try to fix my iPhone i was told that if theres a hole then nothing will get it out of recovery mode until i fix the logic/ mother board.
Questa è una buona domanda?
Punteggio 2
1 Commento
iOS Data Recovery and iOS Recovery Mac provides three simple ways for any iPhone iPad iPod users to directly restore the lost and deleted data, or extract the lost data from iTunes or iCloud backup with ease. So, you can get back lost iPhone data after upgrading to iOS 10/9.3.3/iOS 9.2/iOS 9 with the help of this software. Besides, you are allowed to fix iPhone stuck in recovery mode/DFU mode/white Apple logo screen/black screen and so on with a click.
da
Aggiungi un commento
7 Risposte
Risposta Più Utile
I don't think the fix should be that expensive, $225 cost more than the logic board itself. As you've mentioned, you're able to get the iPhone to be on recovery mode after plugging into computer, so it appears to be some sort of recovery mode loop. You might want to try this software called TinyUmberella, you can use it to exit the phone out of its recovery mode.
The program will detect the device straight away after you plug it into your computer, heres the full instructions + download link
After its out of the recovery mode, you might need to restore the iPhone, you'll lose current data so here's how to recover those data (Extract data from iPhone through Recovery Mode)
Otherwise, if the software doesn't fix it, you might've accidentally pryed/damaged the jumpers off the motherboard/logic board (but I found it quite unlikely that you have digged a "hole" if its still able to turn on, especially since you were only replacing the battery). It seems like a common problem, so you might want to have a look at these threads as well:
iPhone stuck in Recovery Mode after Battery Replacement.
iPhone 5 stuck in Recovery Mode Loop after Battery Change
Broke off Small Jumpers while Prying Battery out of iPhone
Punteggio 1
I don't understand what you mean by, "A hole" Is there a hole in the mother board? That sounds quite strange if that's the case. Could you take a picture of what you mean? When you took the battery out of the phone, did you pry it between the logic board/motherboard (it's the same thing) or did you take it between the chassi/battery?
If you pried between the battery/logic board it's possible you've damaged the logic board.
You can try to use a program called Tiny Umbrella which forces it out of recovery mode.
Punteggio 0
When your iPhone is stuck in recovery mode, you can have a try of the following steps with iPhone Data Recovery:
Solution 1 : Turn off your device , then turn back on and everything should be fine.
Solution 2 : Plug your device into a PC or a MAC then iTunes should detect your iPhone stuck in recovery mode and release you from recovery mode.
Punteggio 0
my iphone stuck in recovery mode too. When I google this problem, I found iPhone Data Recovery, which worked.
Punteggio 0
You can try this way by following steps:
1. Factory Reset your iPhone to Get out of Recovery Mode. In this process, all your data will be erased, so you should back them up before recovery.
2. Exit Recovery Mode with iPhone Data Recovery. After that, your iPhone will be restored and everything will return to normal.
That's it, it is not complicated. All you need is iPhone Data Recovery this recovery tool.
This is the tutorial: iPhone Stuck in Recovery Mode that you can visit for more details.
Hope it helps!
Punteggio 0
Email jessabethany@gmail.com best in the business at repairing logicboards
Punteggio 0
If you want to know how to recover deleted files from iPhone/iPad/iPod Touch. You can try FonePaw iPhone Data Recovery. It can help you reocver files which was deleted by accident. I think you'd better back up your iPhone/iPad/iPod files to iTunes so that you can get them back quickly whenever you need. Hope your problem can be solved.
Punteggio 0
Aggiungi la tua risposta
jonisha sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,045
