Salta al contenuto principale
zune won't charge, any service shop?
hi, I assume it is the part in the device which connects to the cable, anyone can help?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
ariel, your assumption could be right, but first you want to check a few things. Try a different cable and try a different computer or AC adapter. If that still does not work, replace the battery. Use this guide for the repair. Should a new battery still not work, then you are looking at a logic board repair. The connector is solder directly to the board. It will require some good tools and great skills to change that. Hope this helps, good luck
Punteggio 1
2 Commenti:
thanks, very helpful, the only thing is I live out of the States and it won't be easy to get the parts I need.
da
ariel, there are plenty of international company out there that might ship to your country. Give those a try.
da
Aggiungi la tua risposta
ariel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,074
