Salta al contenuto principale
The LG Optimus G was announced on September 19, 2012. It is a smartphone designed and manufactured by LG Electronics. In the US it is available through AT&T and Sprint. AT&T carries the 8-megapixel camera E970, Sprint offers it with a 13-megapixel-equipped LS970 model.
20 Domande Visualizza tutte
Why my lg optimus g e970 doesn't turn on?
after unplugging my phone to the charger, it showed a yellow screen that said:
HW reset was detected!
DemiGod Crash Handler: HW reset was detected!
Press key to choose Dload Mode / Reboot / Fasatboot.
1) Vol up: Dload mode.
2) Vol Down: Reboot.
3) Power: Fastboot
If you choose Dload Mode,
Please do the Following action.
1) Dload Mode. Please connect USB
2) Get the ram dump image using QCT's Memory Dubug App
3) Send email to contact point or M-TDR_Leader@lge.com
after that, press the power button for 15 seconds, and the phone was shut down and will not be returned to power on..
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
This may not answer your question completely, but that screen can be reached when an app crashes your phone. The part about it not being able to turn on is a little more unsettling. If you're willing to go out on a limb, you could open up the back of the case and remove-reconnect the battery.
If it doesn't boot after this, you may have to do some serious hardware debugging. Generally if your phone can't even get into recovery mode, it's a bad sign.
Punteggio 0
Aggiungi la tua risposta
Carlos sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,759
