Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iPhone5 won't restore (error 2001) after screen+battery replacement.
Hello I got a screen replacement for iPhone 5. After I connected the screen I got a white line across it. I read it is due to battery getting disconnected so I reconnected the battery. Got even more white lines.
After reconnecting battery / screen several times I finally got the iPhone to boot without white lines.
Except this time it was a boot loop.
I tried restoring it via iTunes, but no luck.
The iPhone will also not start without USB.
iTunes gives error 2001.
iPhone is not jailbroken.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
I'm going to guess pry damage behind SIM tray on motherboard---but mostly because I fixed nine phones with that problem today :)
If a component called U3 is damaged the home and power button will not work and phone will boot to recovery mode. Fix = replace U3
Punteggio 2
2 Commenti:
And what is the cost of replacing a U3 please?
da
Or just try a different battery. The connection between the battery and motherboard may not be secure.
da
battery is not giving proper power in logic board
so only change the battery and solve the problem
Punteggio 1
Try this www.support.apple.com/en-us/TS3694.
Punteggio -1
Aggiungi la tua risposta
zzzbog sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 8,908
