Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2191 Domande Visualizza tutte
Domanda Chiusa
iPhone not boot up, can not restored. Error 2001
iPhone not powered up, can not restored. Error 2001.
Booting up only from wall charger, charging. After country
selection-showing Connect to iTunes.
I try to restored from iTunes but every time same fault-2001. Some of the with the same fault has a battery problem. I replaced battery today, but still the same problem.
Questa è una buona domanda?
Punteggio 0
3 Commenti:
Leave on charger over hour. Still the same.
When phone connected to the charger after 5 min screen become grey and
phone stuck until disconnect
da
Previously has a minor water damage. I did pull logic board out and cleaned with alcohol. No any signs of corrosion or any other damages on the board.
da
Found short circuit at the battery connector at main board. Power I/O
is heating up when charger connected.
da
Aggiungi un commento
1 Risposta
Leave it plugged into a wall charger for at least 15 minutes before you try a restore, this will rule out that the battery is dead,to finish a restore the phone needs enough battery power to be powered up on it's own.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 482
