Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Domanda Chiusa
Home button doesn't work even after repair.
I have an iPhone 5 in shop that the home button doesn't work on. I've replaced it 5 separate times and each time it doesn't work. I've tested the charge port in a different phone and it works, but when I tested the charge port from the second phone in the first one it still didn't work. I don't know what the problem is.
Another tech here that can activate the home button by pressing the prongs on the charge port a certain way and it works perfect. I've adjusted the prongs height in various different ways also. I just can't get it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I would just try a new charging port just to see if it works
Punteggio 0
2 Commenti:
Well I did that too. Nothing is working.
da
Then if you have tryed all new parts and they are working in other phones it points to a motherboard fault
da
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 187
