Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2396 Domande Visualizza tutte
Domanda Chiusa
My microphone doesn't work after screen replacement.
I replaced my screen on my GSM/AT&T iPhone 4. All other phone features work great, except for when I'm in a call, and the phones speakerphone feature is active, the caller cannot hear me. I've cleaned the noise canceling port next to the headphone jack, and I've ensured all connectors are tight. I can record my voice in a voice memo, and make calls just fine without using the speakerphone. I could use any assistance, I cannot figure this one out.
Thanks a lot everyone.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
hi there seems like you have damaged it in some way voice memos use the upper mic..
install a new dock connector as the mic is attached to it
Punteggio 0
I have installed a new dock connector. It is malfunctioning in the same exact way. I ordered a new proximity sensor ribbon as this has the noise cancelling port on it and I had heard that this can cause similar problems. Please let me know if anyone has any other ideas.
Punteggio 0
You have a problem with the audio ic look on YouTube an type in leon Stacey audio ic
He was a fix for this
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 535
