Salta al contenuto principale
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
Squeaking noise when start up on Maytag Bravos Quiet Series 300 dryer?
The dryer is squeaking when beginning a cycle
After it is warmed up or in use for a few minutes it seems to not be as bad
Is there an easy troubleshooting method?
Could it be a bearing or is it a belt?
Where do I begin?
Questa è una buona domanda?
Punteggio 6
Aggiungi un commento
2 Risposte
Risposta più utile
I find your photos of a repair on a GE dryer interesting, but this is not the same design as the Maytag (Whirlpool) dryers. The Bravos 300 series are very similar to the Maytag Neptune series.
To replace the two wheels (located inside the rear of the dryer) on which the dryer drum rides - these do wear out depending upon frequency of machine use and size/weight of the loads. The front of the Maytag machine must be removed, then slide the drum out, and use a ratchet with socket to remove the two wheels with their holding bolt. A kit containing all the necessary parts can generally be purchased through an appliance parts center for about $40-50. Be sure to have your model number when ordering/purchasing the parts.
Punteggio 2
It's probably a worn out drum bearing. Here's a pictorial guide on replacing one: http://marksprojects.wordpress.com/2009/...
Punteggio 1
Aggiungi la tua risposta
rick sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 25
Tutti i Tempi: 17,357
