Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Domanda Chiusa
Home Button won't work even after rapairs
i have a iphone 5 i opened it one day to replace the home button and everything was fine, a few weeks later i opened it again to change it again. this time when i replaced i the button stopped working.
i have tried replacing the home button cable but even that didn't work.
does anyone have any other advice for me because it's making me go crazy i just can't figure it out
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Does the button still click? Check the alignment of the replacement flex cable if you haven't already. On the dock, check that the little contacts are standing correctly. If they aren't tall enough or are crooked it won't work.
Punteggio 0
1 Commento:
i was thinking that maybe the connectors weren't touching but how can i make sure that they are, because you can't see it when you close it
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 69
