Salta al contenuto principale
Modello metà 2010, A1278 / processore Core Duo 2,4 o 2,66 GHz
794 Domande Visualizza tutte
MacBook won't charge with new battery and charger
My Macbook won't charge after replacing the battery and charger. My warranty is up and I don't have the money to send it in to be fixed. When I plug charger in, the light on the charger doesn't turn on. Sometimes if the charger is in perfect position it will charge for a few seconds and then the light will go off again. Any help would be useful.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Use a toothpick and move the pins in and out on the Power Adapter..Next use a multimeter to test the output of the pins and see if you get 16.5 volts. On the right of this wiki is a picture of the pin out: http://en.wikipedia.org/wiki/MagSafe
Next replace the Mag=safe board, here's how: MacBook Pro 13" Unibody Mid 2010 DC-In Board Replacement
Punteggio 1
If you look in that picture you will see a very thin white gasket around the pins.
I had same problem and it turned out for me it was just the insulating gasket in the external port. I found part of it still intact and guessed partial insulation might be that causing a short.
The gasket is made of very thin tape and sure enough when I made a copy and put that in, it charged fine on the new charger I had bought. The old charger is dead (on this and a friend's machine) so I presume it was fried shorting while I repeatedly tried to charge before. P.S. I made the copy of the gasket size needed by making an inverse template by pressing Blutac into the magsafe port hole and used that as a block to print an outline onto the tape. For me I didn't even need to open the mac up!
Punteggio 1
Aggiungi la tua risposta
zack sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,413
