Would a powered usb hub power 3 hard drive at one time?
Hi, my macbook pro only has two usb ports and i need to hook up 3 hard drive for editing. i tryed a non-powered usb hub and it didnt work do you think a powered usb hub would work? im looking at this one. http://www.amazon.com/gp/product/B005C32...
i also have a pogoplug i want to use this usb hub with would it work for that two?
Questa è una buona domanda?
7 Commenti
Which hard drives are you using now, and which do you plan on adding to your setup?
da steve
Right now i'm using one owc 500gb sata hard drive and one smaller 6gb apple pata hard drive i plan on getting another 500gb hard drive. But all i know is i need something that will power these i tried to use a 4 port non-powered usb hub but it shut both of them down so could you help me find the right one? i would also like to use the usb hub for my pogoplug Thanks
da Carson481
Do any of your HD's offer a DC power input? If they do you might want to get a AC power adapter that will work with the HD's that have the power option Vs using a powered hub. While some hubs will work to support a single drive pushing two or more drives could be too much for it. Don't think because you can access the drives its safe to read/write to them. Remember the load is when the drive is reading & writing, which could cause non-recoverable errors.
da Dan
No all my HD's are not ac powered only powered buy a usb port on a computer so your saying buying a powered usb hub would be useless?
da Carson481
dose anyone think this one will work?
http://www.amazon.com/7-Port-Powered-Ada...
It gives off 500mAh
da Carson481
Mostra altri 2 commenti
