Salta al contenuto principale
track pad button stuck on
The trackpad button on my MBA seems to be stuck on so when i move the courser around the screen it highlights everything. if i plug in an external mouse I'm able to deselect the highlights and it works fine.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Thank you for the reply. However I should have made it clear that the button isn't stuck in the down position (I can still click it) it is just acting like it is down when I move the mouse across the page.
da
My mac air is only a year old. It started bouncing around after a few months but disappeared. Now it is doing it again only not going away. Everyone says Mac is the best but I am not convinced. the pad now has a mind of its own and moves around.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Run a stiff piece of plastic ( preferably with a sharp point)around the trackpad seam and see if you can dislodge anything.
Punteggio 3
Aggiungi la tua risposta
jeff sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,160
