Removing LCD from digitizer
Is there a way to remove LCD from digitizer?
Questa è una buona domanda?
vonta30, not for the common DIY'er. The digitizer and LCD are bonded together. In order to separate it, you would need some very special equipment. Even if you have it separated, you will still need more special equipment and adhesive to reassemble it properly. I suggest that you replace the complete display assembly unless you have the right tools and expertise. Hope this helps, good luck.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 187
