Salta al contenuto principale
Si tratta della 6° replica di Iphone Apple, annunciata il 12 Settembre, 2012. La riparazione di questo dispositivo è del tutto simile a quella delle precedenti versioni di Iphone e richiede l'impiego di cacciaviti e strumenti di apertura. È disponbile con tecnologia GSM o CDMA, con 16,32, o 64 Gb di memoria, nei colori nero o bianco
3351 Domande Visualizza tutte
Stuck in recovery loop, new motherboard?
The phone had water damage and we did a full water damage repair with new battery and charge port.
The phone is an has been stuck in recovery mode. All ready tried tinyumbrella and put it in DFU mode and all. It's simply not fixing it.
My question, if I just got a motherboard replacement, wouldn't that fix my issue?
I never purchased a motherboard and not sure what I need to look out for if so. Obviously clean esn, working board. But anything other than that? Can I get one that had any service ?
Please help, I'm newb to this part.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Batterie per PC portatili
Una soluzione semplice per un grande aumento di potenza.
Acquista ora
Acquista ora
3 Risposte
It seems that your motherboard of you iPhone 5 has waterdamage. It can't be fixed.
I don't think you can purchase a brand new motherboard on the market.
You can hunt a secondhand in the flea market.
Punteggio 0
Only way to get a motherboard is to buy a second Hand iPhone 5 and take motherboard from it..
Punteggio 0
Your wrong con. You don't have to buy a second hand iphone 5 to get a motherboard/logic board. You can purchase a logic board on eBay and other sites. Respectfully, don't answer questions when you don't know the answer.... Also, you didn't even answer any of the questions.
Punteggio 0
Aggiungi la tua risposta
adam sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 126
