Unresponsive screen when connecting proximity/camera flex
Hi Guys.
I really hope someone has had this problem & resolved it.
I have just replaced the screen & proximity/camera flex i had to as the proximity sensor was also damaged.
The replacement screen works fine without the flex but as soon as i put the proximity/camera sensor with the receiver together the screen becomes unresponsive & has vertical lines.
Its not just with one screen its doing it with any screen i install.
The replacement proximity/camera flex the only difference is the copper shielding which is stuck to the metal backplate of the screen seen being removed here.
http://d3nevzfk7ii3be.cloudfront.net/igi...
The replacement doesn't have any at all its identical to the one in the guide here
Do i need to remove the shielding & attach it to the replacement proximity/camera flex? & could this be the reason why when i assemble everything it causes the screen to become unresponsive?
Any help or advice here would be greatly appreciated.
Thank you
Questa è una buona domanda?
