Keeps crashing at first screen
Phone crashes at the samsung galaxy s2 screen. Any ideas what might be wrong and how to fix it?
Questa è una buona domanda?
You can try to clear the cache from the recovery menu -power Down and hold home power and vol up together otherwise factory reset from same menu if all else fails relaid the firmware using Odin
It crashes on the first samsung galaxy s 2 screen so cant access menues. Seems to be oveheating a tad so any idea how to sort that or is it just time for a new phone?
so take the battery out, put it back in and pres power vol up and home buttons together this will put you in the recovery menu from here select clear cache if still not booting try the same method this time selecting factory wipe reset. If this still fails download odin and your firmware file if you need more help with reloading the firmware let me know :)
@ashdoodles82 can't go into download mode either? ensure device is off then hold home power and vol down sometimes it can take a few goes and hold them in until after the samsung logo appears
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 124
Mines doing this also, but I'm not able to access the recovery menu.
da ashdoodles82
