Salta al contenuto principale
What is the best way to remove my stripped fan screws?
I have two stripped screws one on the processor fan the other on the speaker assembly what is the best way to remove these screws?
Questa è una buona domanda?
Punteggio 0
2 Commenti
This belongs in the regular iFixit discussion and has been flagged as such.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
To unscrew a stripped philips screw I use a modified very small flat screwdriver. With a sand paper or a stone that you use to sharpen knives I modify the square tip giving it a 45 degree shape on each side until the tip enter in the head of the stripped screw then I apply pressure on the screwdriver while unscrewing and most of the times it works.
Punteggio 1
1 Commento:
like +
da
I found these screws to be very soft and the head easy to damage. I managed to get them out by pressing really hard (standing up using my weight) while turning very slowly with the Philips #00 screwdriver.
Punteggio 0
Aggiungi la tua risposta
yourcomputerworks sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,379
