Can I create a fusion on late 2013 iMac 27?
Hi, i recently bought the latest iMac 27" and it's delivered with 1Tb HDD, no fusion drive preinstalled. I also find out that i can add a SSD on PCIe slot(since it's empty) and my intention is to create a Fusion Drive with a SSD (PCIe) mixing the original 1Tb hdd and the 256Gb that i will install by my own.
I specify that the SSD cames from a macbook pro retina late 2012 (mz-dpc2560/0a2)
Is anything wrong on my plan?
Thank you
UPDATE
SSD Serial /model
Questa è una buona domanda?
4 Commenti
Bogdan - While the part & chips may look the same these are not interchange parts. First there is the Samsung controller while it's the same part (as you noted) it is also programed (note the word ARM in the bottom right of the chip). There is firmware that is written into the chip to configure the SSD's interface. So while the chip is the same, the I/O part of the connection is not sending the signals in the same manner between the mSATA Vs PCIe versions of the part. Second, the Flash chips them selves are different speeds here 216 Vs 240 and the higher speed version is what is required in the iMac.
da Dan
I just don't know of any supplier of SSD upgrades for the newer iMac's yet. Apple is right now the only source for there version of the M.2 PCIe SSD's. While I commend you on trying to reuse your older MacBook Pro retina SSD it is not interchangeable with the newer iMac. - Sorry ;-{
da Dan
Ok, thank you, i Will try finaly, as i already have all the components, and once it's done you will have an answer based on a real test.
Thank you for your advice.
da Bogdan
Photo added, and btw on both repair guides(iFixit): MacBook Pro retina 15", and latest iMac 27", flash SSD's, to me, it seems to be identical.
da Bogdan
