Dell Inspiron 1545 shutdown problem?
Has windows 8 installed
It only stays on for 4 minutes then shuts off
Somebody please help
Questa è una buona domanda?
Forbes Gaimg, sounds like an overheating issue. Start off by cleaning the air inlet vents. Make sure that you have enough air circulation. If that checks out okay, disassemble your Dell, clean the fan and check the thermal paste. Check your Fan to make sure that it works. Hope this helps, good luck.
How can I clean the air inlets without the use of canned air?
You could use a vacuum cleaner and a soft brush. Or you could disassemble the laptop and use the vacuum cleaner and a soft brush again. Download the service manual from the device page. Dell Inspiron 15 (1545) and scroll all the way down. Click on the blue link to download it.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 228
