Salta al contenuto principale
La famiglia MacBook è stata introdotta nel maggio 2006, sostituendo l'iBook nel ruolo del laptop Apple indirizzato al mercato consumer.
3787 Domande Visualizza tutte
Domanda Chiusa
Computer doesn't start after cleaning
Hello, I have an issue with my MacBook mid 07.
My computer was running slow and encountering a lot of failures. So, I thought, I would give it an internal clean and reapply thermal compound to the CPU. (I've taken apart many machines in the past, and have a strong technical knowledge of computers). I removed everything from the base casing, and cleaned everything with a cotton swab and rubbing alcohol. After rebuilding, my machine will not start under any circumstance. If I plug in the MagSafe charger, I get two flashes of green then a solid green, as if the battery is fully charged, even after completely removing the battery. The machine does not start on battery alone either. I notice, that while plugged in, the area an components located left of the CPU get extremely hot over time. Did I damage the logic board upon maintaniance, or is there still hope for this machine? Any thoughts are welcome. Thank you.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Damage is always a possibly - I would suggest you go over all your connections again. Many times reassembly issues trace back to a connection that was incomplete.
Next thing would be to try an SMC reset.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
3 Commenti:
i took everything out of the case, and discovered that wiggling the magsafe, and holding the power button, i could get the fans to rev. any other ideas
da
Julian Gray - For future reference you posted a Comment in the place where only Answers belong. Please use the add comment link to the appropriate Answer or update your O.Q..
da
Replace the DC-in board?
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 105
