Presario V2000, comes up NTLDR missing
truns on but just goes to screen that says ntrdl is missing, wont do a restore from f12 either
Questa è una buona domanda?
penny, this is most likely a software error. Check on here for a few things you could try out. If F10 or F12 does not restore your operating system, you may have a bad partition or even a bad drive. Set your BIOS to boot from optical drive and run your computer from a Live Linux CD and see if you can access your hard drive and if it has multiple partitions. The smaller partition should be the one that contains your OS recovery. It can only recover the OS if it is still there, if anyone deleted or reformatted the drive, it most likely is no longer there, but see what you can find out.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 181
