Repair guides and support for cars manufactured by the Nissan Motor Company Ltd.
302 Domande Visualizza tutte
How to fix the speedometer
The speedometer needle is hurried at 125 at about 30-35 mp hit starts to work but it goes backwards! Just recently in the snow I got it to flip back to 0 and it worked for a short time but as I was entering the freeway from the on ramp I brought the rpm up to about 5 1/2 on the tach it jumped back to 125 now is working back wards again !!! Help please be for I get pulled over for speeding. 1991 Nissan Maxima
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
jack mehoff, it is possible that you have a bad speed sensor. This sensor sends the signal to the speedometer and from there a processor sends the signal to the ECM. Your speedometer gets its feed from the same place as the odometer. Typically if you have a working odometer, but intermittent speedometer, then the instrument cluster itself is bad. Hope this helps, good luck.
Punteggio 1
Aggiungi la tua risposta
jack mehoff sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,672
